workinforwood
I was wondering if anyone can tell me about the tip of a bullet. Does the lead tip get drilled before installing it in the casing?
The least expensive (but perfectly adequate) presses are made by Lee Precision http://www.leeprecision.com . The bench-mounted "Lee Reloader Press" and the portable "Lee Hand Press" each retail for $30.00. A set of Lee "PaceSetter Dies" (which include sizing, seating, and crimping dies as well as a shellholder) costs $30.00 for most rifle calibers.Originally posted by Charlie in Garfield
<br />Do you know if any one makes a hand crimper to put in bullets.
I agree. With a hollow-point of the correct size, you can even eliminate the need to drill the point. A boat-tail bullet will be easier to seat because you don't need to bell the caae mouth, nor to remove the flare afterwards. For slimline pens, I've settled on the 168g Hornady A-Max bullet (hollow-point boat-tail (HPBT) with polymer tip). Once drilled out from the base, the polymer tip can be cut off. I end up with a hollow point that is a good size for a Cross-style refill.Originally posted by cbonner
<br />I am guessing it would be easiest to start with a hollow point bullet, as the opening would assist in getting the drill bit started correctly.... look for HP or HPBT nomenclature on the box.
Midway is good. Midsouth Shooters http://www.midsouthshooterssupply.com/ is also. Both carry reloading equipment and components.There used to be a hand tool that coult be used for seating bullets, ... Midwayusa.com would be a good starting point for such items and they have reasonable prices.
My biggest problem is the drilling operation. ... my drill bit wants to wander all over the place! Now I have some stub drill bits and the short drill/ countersink bits on order.
Originally posted by rd_ab_penman
<br />Hi Jeff,
To seat my bullet nibs I use my drill press. You don't need to spend money on special tools
To drill my bullets I use a drill chuck in my headstock to hold the bullet and put a drill chuck with the bit I am going to use in my tailstock.
Regards,
Originally posted by TBone
<br />Originally posted by rd_ab_penman
<br />Hi Jeff,
Regards,
Les, do you epoxy/glue/solder your bullets? Pressing them in seems fairly simple but the reloader crimps them also. Do you have any trouble with them holding when you press in the transmissions?
