The mechanism itself is mushrooming out right at the bottom of the mech as you try to press it in?? You may want to make sure that you are reaming the brass tube properly before you try to seat the mechanism. There could be solder in the tube, and if that's in the way you will have problems like this. Try a kit using CA (superglue) and see if the problem goes away?
It is possible they changed vendors who provide them with the twist mechs ... try calling them up and letting them know that you're having problems, they may replace the twist mechanisms for you for free! If that doesn't work, you can try a 3rd-party vendor.
