Bullet Cartridge Pen Kits
Stephen
Singapore, 568198.
Have searched without success. Does anyone sell bullet Cartridge pen kits like the PSI 24k click kits in a twist ballpoint with Platinum or TN gold. Thanks.
nava1uni
San Francisco, CA, USA.
You can buy the bullet with the transmission installed from several people here. Then you just make your own top and add whatever clip you want to use. But I have never seen them in anything other then brass and nickel.
KenV
Juneau, Alaska.
Cartridge pens were a development using actual cases used in firearms -- and those are generally brass (occasionally steel with a brass coating for some military shells) and can be purchased new from reloading supply firms with either a brass or nickel plating surface. The pens are adapted to using those by drilling out the primer pocket and using either an actual bullet, or with some adaptation, the tip from a slimline kit. Plan c is to make your own nib from brass or corian or similar.
Some have used powder coatings to add to the durability and resistance to tarnishing of the case surfaces.
Slimline tips can come in any finish -- but are ball point form. Several have drilled out bullets (I like the all brass bullets) for rollerballs and gel roller style pens.
PSI recently went to the market with a cartridge like pen -- Drop me a PM if you want a few empty cases to learn with and you can make your own with a few slim line kits -- Think the gun metal slimline kits to have the "bullet look" without drilling out bullets or making your own nib.
Stephen
Singapore, 568198.
Thanks for the information. I discovered I will have problems getting them into the country (restricted item). I am giving it a miss.
Stephen
