You don't need the EEE. I have some and haven't used it in months. I wet sand through 2000, then buff with Tripoli, White Diamond, then Carnuba.
This one needs to go back into the finishing for some CA build up, but I did the above with it.
I thought EEE and tripoli were the same thing.
I thought it was the same too. Isn't it?
There is a product callled EEE shine or words to that effect---it is a paste and can be used on the lathe---not a bad product, but if you have the buffing station, there is no need to "polish" on the lathe. (IMNHO)
Actually, I think its called EEE Shellawax and comes from Australia---it's in my shop, hasn't been used for years.
Shellwax, and EEE-Ultra Shine are two different product lables made by the same company. Penn State is the "importer and master distributor", but you can find them in other places.
Shellawax Cream: 300ml Jar at Penn State Industries
EEE-Ultra Shine Paste Wax: 250ml at Penn State Industries
EEE-Ultra Shine "contains" tripoli, but I'm guessing that it's got something else in it to help the process.
Even then, I think it's better to use a buffing system since it removes the "Radial" scratches. EEE works good, but it's easy to get the bushings in there (DAMHIK) and have metal shavings in your wood. This of course can be solved with finishing bushings. It doesn't necessarily take out the radial scratches.
Also:
HF is good for the buffs, but Menards has a very nice "soft cotton" buffing wheel for a decent price. I bought one and like very much. It's made by Weller (guess they make more than soldering stations).
8" Buffing Wheel at Menards
I don't know if I'm doing it right, but it's nice for applying the final Carnuba coat. It does however, appear to be different than the Beal wax buff.
There has also been some discussion on the Caswell buffs and compounds. I've never tried them, but it looks like those that have seem to like them.
Before I lost my shop space, I was using the HF buffs and the final Menard's/Weller buff. Since I'd not yet set up a buffing station, I mounted them on arbors and used the drill press. The previously posted pen was done with this method, and while I need to do some more build up, it shines great as is.
Sometime I don't even do that. Instead, I'll wet sand to 2K, and then go straight to plastic polish. The following two pens were done with this method.
*Finally got the "quote" straightened out. :biggrin:
