Splinter
I have read that some people plug the end of the brass tubes with playdough, wax or some other product before inserting the tube into the blank to keep the glue out of the tube.
What method are you using for holding/inserting the tube into the blank after you get the glue on it?
I currently use a insertion tool (cheap nail set) to insert the tube after spreading the CA on the tube. And sometimes I get a little glue in the tubes.
Also what is the best product to use to plug the tubes?
