RDH79
has anyone come up with a good fix for the tube twisting on the transmission? (On Slims) I have been having this problem more than usual.
The brass tube is twisting on the trans and not working the refill. I do think that my 7mm mill might be the problem. Over milling. I usually square the blanks close with a carbide mill and finish on the edgesander.
Also the kits are Tigld but not sure if the tubes are really the problem. I also buy lots of extra tubes from CSUSA And I get the Apprentice tubes. There .5 cheaper than the regular slim tubes for some reason. so not sure which ones that are doing this. I just had 2 of the last 10 slip.
Simple fix for this is to dimple the transmission from the inside with a very small transfer punch. Do this in 2 or 3 places. These dimple will grab the tube. I have also used a pair of needle nose pliers and SLIGHTY flared out the top opening on the tranny.has anyone come up with a good fix for the tube twisting on the transmission? (On Slims) I have been having this problem more than usual.
Assume you're asking about slimlines? If so, a few swipes with 80grit sandpaper on the transmission seems to work best for me. I've seen other suggestions such as deforming the transmission a bit with a punch but that didn't work well for me -- YRMV.
On those where the transmission is really stiff, I spray WD-40 in the transmission. This really makes the tranny loose to fault though and I use this only as a last resort.
One more of the reasons I don't like making slimlines. I wish I could find a source of high quality slimline transmissions because I have some customers who prefer the thin shape :frown:.
