Brass tube showing - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 02-18-2019, 09:58 AM   #1 (permalink)
Photos: 0
Default Brass tube showing
Iím a novice so Iím after a bit of help. I have turned a Euro twist pen in acrylic that is fairly translucent and because the nib end is quite thin you can see the brass tube through the acrylic. The top tube is okay because itís thicker. Any ideas that will help?
Pauls is offline   Reply With Quote Top
Old 02-18-2019, 10:04 AM   #2 (permalink)
walshjp17's Avatar
Photos: 5
Default
Quote:
Paint your drilled holes prior to gluing in the tubes on acrylics. I use a q-tip (or similar applicator) to spread the paint in the hole. You can also mix a bit of the same color paint with the epoxy used to glue in the tubes.
I use acrylic paints such as Testers, but others use spray paints. Use a color that will complement your blank as it will likely look decidedly different after painting the holes.
__________________
ZipIt!
John
USN (Ret)
Carolina Piedmont Chapter
walshjp17 is offline   Reply With Quote Top
Old 02-18-2019, 10:04 AM   #3 (permalink)
BURLMAN's Avatar
Photos: 10
Default
As far as that pen goes, I have no suggestions or solution. For future pens paint the inside of the drilled hole using the same color paint as the acrylic before gluing in the tube. Allow the blank to cure overnight before gluing.
Ah, I see John posted his answer as I was typing mine. His is better and more thorough.
John
(Also USN retired)
BURLMAN is offline   Reply With Quote Top
Advertisement
Old 02-18-2019, 10:11 AM   #4 (permalink)
Local Chapter Manager
ed4copies's Avatar
Photos: 27
Default
https://www.youtube.com/watch?v=wdtZvq9A7nQ
Talks about color to reverse paint
https://www.youtube.com/watch?v=jbOb1UJnqdY
Talks about WHY and When to paint
Hopefully that will help you understand and solve your "see the tube" problem
WELCOME to IAP!!! LOTS of problem solutions!!!
__________________
Ed Brown
ed4copies is offline   Reply With Quote Top
Old 02-18-2019, 10:44 AM   #5 (permalink)
Photos: 0
Default
Simple, why didnít I think about that. Thank for the help
Old 02-18-2019, 11:15 AM   #6 (permalink)
TonyL's Avatar
Photos: 6
Default
I do what Ed does basically for all non-opaque purposes. I just shoot the paint in hole of the barrel (sloppy, but I don't mind) I also paint the tubes (just a extra step - heck, the paint can is out and well-shaken, why not?). I do wait a full 24 hours before gluing and I only use epoxy. Keep in mind, that many, many others have excellent results practicing different processes. It is only a "poor" process, if it doesn't achieve the results that you are looking for. I like the Rustoleum and Krylon lines. I try to find flat colors or the primers.
Enjoy!
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 02-18-2019, 01:28 PM   #7 (permalink)
More4dan's Avatar
Photos: 5
Default
Clamp your newly painted blank in your chuck and spin at max RPM for a few seconds. It will even out the paint leaving a consistent smooth finish.
More4dan is offline   Reply With Quote Top
Old 02-18-2019, 03:30 PM   #8 (permalink)
Woodchipper's Avatar
Photos: 1
Default
I bought some tubes at WC that are painted white for such occasions.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 02-18-2019, 03:58 PM   #9 (permalink)
Photos: 4
Default
Quote:
Iíd paint the holes even when using white tubes because the glue can still show up splotchy if the blank material is translucent enough. Some blanks are so translucent that at least in my hands, they look awful even when well painted- you can still clearly see the painted surface of the hole
__________________
"In theory, there's no difference between theory and practice. In practice, there is."-Yogi Berra
Shock me is offline   Reply With Quote Top
Old 02-19-2019, 08:49 AM   #10 (permalink)
Photos: 1
Default
Shock Me, good advice, never thought of that as I haven't had occasion to use the white tubes yet. Thanks!
__________________
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
