Brass Tube
LouF
Hemet, Ca.92544
My wife turned a pen in acrylic the pen is Pink with pearl the problem is we can see the brass tube inside the acrylic. What do you guys think will keep this from happing in future pens?
Thanks Lou
Tom T
Sanford Florida
Great question. I had it for a long time also. I had to ask what reverse paint means. Then a nice person on this web site told me. After you drill the tube. Paint the inside with a similar color to the tube. Or white often works on most colors. Also I generally buy white tubes at the WC. (Wood Craft) Some of our venders on this sight I am sure sell them also. Buy the proper diameter tube. They are cheap. The white tube work okay except that you can still see the glue through the pen blank after it is turned down. Some times that is not a good thing. If you paint the inside of the tube ( called reverse painting) you can not see the glue it is behind the paint. I use CA glue by the way, but others use other things. Use what works for you. Still rough up the white pre painted tube that you buy but do not let the brass under the paint show through. The people on the sight use several type of paint. Model paint has been mentioned several times. I am sure there are tutorials in the library on this topic. Good stuff there.
randyrls
Harrisburg, PA 17112
Tom; Really great suggestions! The color of the clank can be changed by the color of the underlying reverse paint color. Both these pens started out with the same blank. The difference is the color of the reverse color.
bgio13
Oak Bluffs, MA, USA.
I use the little jars of Testors modeling paint to paint the inside of the blanks. I don't bother painting the tube. I ended up scratching the paint on the blank because I built up too much paint and the tube wouldn't go in. I also dab a toothpick in the paint and tint the epoxy for good measure. Hope this helps,
Bill
