HoratioHornblower
Hi all, I recently ordered some stuff from a site and I had ordered some standard bits. (those that are the cheapest option) Two of the bits were out of stock I guess so the company replaced the standard bits with Brad Point Bits, which is I believe an up grade. Sadly though, when I use at least the one brade point (haven't tried the other) it makes the hole much bigger at the entry point than the exit! Does anyone else have trouble with this? I have used a center drill with it, and once I believe I didn't and both times I had the same results. I am drilling on the lathe and I don't have this problem with other bits that are not brad points. Any thoughts? I am not trying to bash the company, just figure out what the problem is and if I should get a new bit. Thanks!
David
David
