Good thing you don't cut through the center Paul, because some of the bowling balls have a ceramic ball inside the core which is slighly off center to make the ball turn as it rolls. You cut into that and even a metal blade will be toast in seconds. Some of them are definitely like concrete inside. The amount of dust created alone is not worth it. If you have a new ball, the skin is real thin. If you can find the really old balls from back early 80's and older, they have thicker skins, thick enough that you can actually cut blanks and I even had one where I scored a couple big enough for bottle stoppers. The skin material is certainly similar to a urethane resin. I don't know exactly what it is. When I cut the new alumilite CC it smells just like the outer shell of a bowling ball.
