Alzey
I have seen several posts about using Blue Loctite for loose fitting parts. Why use this instead of CA? Are you able to disassemble easier if needed?
Hi Andy,
Do you confirm you're talking about Loctite thread sealant and not glue? And are you satisfied with this product? Do you use thread sealant on every pen part needed to be fixed? Is it strong enough even without threads? Any problems?
Thanks in advance for your response.
Christos.
I didn't know about blue thread sealant Loctite. I have but red. What's the difference?
Sorry. I've just read the post above about using the red for a permanent seal.
When useing the Loctite are you useing any type of applicator or just a drop on the parts. How do you prevent it from getting into the mechinisms.
