Blow out
BeeAMaker
Elkhart IN, USA
I was turning along, all is good and suddenly - BAM! half of the blank just shatters off the brass tube. Bad casting maybe? I could see that there was CA on that part so I don't think that was the issue (and I sanded the tube). finger gouge was sharp, I guess it caught just right and ripped it apart.
Which made me wonder something else, Perhaps I wasn't close enough to the brass tube when squaring and the bushings were pressing to tight against the blank itself?
How close do you trim to the blank when squaring? I try to get as close as I can without touching the brass, should I time right up to the brass?
mark james
IAP Collection, Curator
Medina, Ohio
Not sure if I am answering your issue/question.
In the past 12 months, I have turned my blanks to 1/8" proud of the bushings. Then using a headstock sanding jig and a rick herrell tailstock sanding jig, sanded the blanks back to the bushings (Bright brass ring).
Then I finish the final turning and whatever finish...
magpens
Canada
Good plan ... I think it is risky to put much pressure on the blank material by tightening the bushings against the blank
I believe the metal bushings are meant to make good contact with the brass tube.
