bluesguitar
I have two problems with preparing my blanks, and hoping you all can help me figure them out:
1. I'm using a HF variable speed mini-lathe with the PSI dedication pen chuck and drilling my blanks with that setup. The lathe does have some play in the tailstock so I can lock it down in different ways and suspect it could be off by a couple degrees sometimes. The drill bit moves forward as the live center is advanced and things seem to working OK but when I take the blank out of the chuck, the exit hole is off center, sometimes 4-5mm. I haven't wrecked a blank yet, but I could. Do you figure it's the lathe or am I doing something wrong?
2. I'm using the PSI barrel trimmer to line up the ends of my blanks but after trimming down to the end of the brass tube, the wood is still "wavy" as opposed to totally flat. I'm not noticing it until I go to assemble the pen and I end up having to sand it flat. Maybe I'm just not going far enough down on the end of the blank?
Any help appreciated,
Mitch
Mitch
