Good luck! I tried this with the Army and Navy digital prints and while they look okay after casting the issue is watching any overlap in the fabric and it will be a bit too thick and surface as you turn. Mind you, I only tried two castings and moved onto other things, but it can be done.
Any PR from PSI or a craft store will work. I say print out the discount coupon and go to Michael's as it's the same stuff. I found that measuring out the required amount of resin, then heating it till it pours like water helps resolve bubble issues. After that put in the catalyst and pour into the mold. The air bubbles will lift to the surface super fast with the PR warm.
