Big Wooden Pen Box
Liberty, South Carolina.
I need several wooden boxes for Gentlemen pens, so I've decided to make them. Should be no big deal, I make lots of furniture. The problem is, I don't have a 3/4" round nose router bit. I thinking I can use the biggest I have, a 1/2", and make two passes. Then I started thinking, which usually gets me in trouble, that there will be an issue at the ends of the coves, that the ends will not flow smoothly around the radius.
Anyone with experience using a smaller than optimum bit for this task before I waste my time and material testing?
TIA,
Ken
ctEaglesc
Passed Away Jul 4, 2008
Camden, S.C., USA.
I have made my own but I went out and bought a 3/4 round nose bit.
My boxes have a better finish than the ones I buy but I certainly cannot justify the time in making them.
Bear in mind I made mine book matched tops and bottoms out of walnut.
When you are set up to do 25-30 boe xes that means you have a minimum of 50-60 halves and each was cut routed,sanded, shelaced, steel wooled wiped,oiled,sprayed 3 coats of lacquer,stleel wooled between coats,waxed and rubbed.
The the final pieces had to be drilled for barrel(pin hinges)
I did this trying to keep all the pieces matching.
In the process some had to be culled.
The amount of time spent making the boxes would have been better spent turning pens.
I later found that I could buy a Walnut box for $3.50 each.
The finish wasn't as good but I decided to live with it.
I still have one customer that wants me to make her boxes rather than supply imports.
One option you might consider is cut the ends off dado a groove and then glue the ends back on.
You can also buy an overpriced foam insert for the box which is removeable but the box would make a nice catch-all on a dresser for change and pocket junk.
You could also make the box like a small bandsaw box cutting the center section out with a bandsaw or scroll saw,glue the bottom back on(possibly use contrastin wood) and hinge the top.
I ahve not made a gents pen, the largest I have made to fate is a cigar ,but some of my perfit fits have custom shaped tops that don't fit in ready made boxes that have a 5/8ths recesss.
(Yeah, I know, not much help)
I bought my round nose bit at WC before I knew better.
I have since bought bits from wood line.
I bought a set at a wwking show, but I have heard from other wwkers that their online site is pretty good.
They have round nose bits up to 1&1/2"
and prices are pretty reasonable
http://www.woodline.com/scripts/prodList.asp?idcategory=130
<br />
wayneis
Okemos, Michigan, USA.
Ken in a pinch you could do two passes and then using a dremel tool or sand paper finish out the ends. You know, where there is a will there's a way.
Wayne
