Best source for Jr. Gent & Baron
follow3
Hampton, VA
Hi All,
Where is the best place for Jr. gent kits and Baron kits?
I usualy buy kits from CSUSA, but they are out of stock on some of their kits.
Thanks,
Steve
karlkuehn
Banned
Lancaster, Pennsylvania, USA.
Originally posted by Lanman
The Tycoon at PSI appears to be a Baron copy as well.
Aside from the double ring on the center band, I think it's the same kit. Not sure if the brass tubes are the same length as the Baron, to compensate for the extra ring. Everything else looks the same.
MikeInMo
Springfield, MO, USA.
Has anyone turned a PSI Tycoon? If so, what do you think of it? I was wanting to try a Jr Gent but CSUSA is out of bushings for now, so I was thinking about trying the Tycoon instead since it seems similar.
jskeen
Crosby, Texas, USA.
Call CSUSA and ask them about the jr gent/jr statesman/jr retro bushings. I just got a set a couple of weeks ago and they had just received the shipment. They probably just haven't updated the online catalog lately.
James
ed4copies
Local Chapter Manager
Racine, WI, USA.
Another consideration: If you make a Jr. Gent and it turns out spectacular, you can mount it on Jr. Statesman hardware and have a more expensive pen.
Just a FWIW>
