Best pen for watch parts or...
MikeL
Tennessee
I've been looking through the library and forums to find opinions on which pens have the most thickness between the copper tube and OD of the bushing. In case I'm not asking the question clearly, what pen has the greatest difference between inner diameter and the outer diameter for having room for things such watch parts or beer caps.... Thanks for any leads.
theidlemind
Berea, Kentucky 40403
The Aero Elegant is a good one.
Single tube, good platings, quite a bit of meat after you turn it.
Cigars and Jr. Gents work too.
But anything will work, I've done watch parts and nib castings on slimlines.
ed4copies
Local Chapter Manager
Racine, WI, USA.
You MAY want to consider a second factor, as well: What diameter will you have to accomodate in bending the parts. The "tighter" the bend, the more likely to crack the component or it's finish.
MikeL
Tennessee
Thanks for the input. I am looking to try something different and it will require maximum room between tube and OD.
carlmorrell
Cary, NC
Wondering the same thing. I just got a panache kit. 10.5mm & 12.5mm tubes. BIG bushings, so I was thinking this would be a good candidate, when I get a roundtoit.
thewishman
Reynoldsburg, Ohio, USA.
The Sierra Vista or Wall Street III have a good amount of room. Berea Hardwoods, Exotic Blanks, Beartooth Woods and other carry them.
I think the Spring Blossom my have the most room for stuff. It is at the Classic Nib.
