Gonna try out a couple "stripers" (actually, just 45-degree thin strips in contrasting colors to the main blank). Is CA a good glue for wood-to-wood? How about wood-to-Corian? Any better choices?
epoxy or ca will both work fine as would tightbond wood glue. I have used them all but usualy use ca because I always have it on the work bench..you get a stronger bond if you dont use the accelerator,If you can let it cure over night, thats even better
