timdaleiden
I think I have tried every finish out there so far (aside from PPP, and have not been pleased with any of them completely. CA comes out pretty nice, but it is a lot of work to get just right (and yes, I tried the BLO method).
Today I completed my second CA/Laquer pen, and I love it. This pen looks like it was dipped in liquid glass, and I have almost no doubts that it is a durable finish.
In brief, I used thin CA to seal, slurry/grain fill, and harden the outside of the wood. I used 400 wet/dry sand paper for this. I followed with 600 grit, going back down to grain filled wood. I sanded while the wood was spinning, and longitudinally, with the lathe off. I took the mandrel off the lathe, and applied 3 coats of Deft gloss spray laquer, allowing each coat to dry before applying the next. It took about fifteen minutes for all 3 coats to dry. I put the mandrel back on the lathe and used 400, followed by 600 grit. I stopped sanding after I saw I had an even layer of deft of the blanks. No low spots. I then took the mandrel back off the lathe, and applied a final coat of Deft, making sure that I had an even coat. I applied it under a bright light. I let it dry and harden over night. Today I assembled the pen, and it is the best finish I have ever seen on a pen. It is super shiny, and smooth, and yet it is not at all slippery to hold. I didn't need any friction polish, or MM, Ren Wax, or buffing.
If this finish lasts, and I see no reason why it won't, I will clean off my finish shelf...finally.
