rebfan04
Ok..Going to do first Euro style..have held off because didnt want to have to do tenon. Any suggestions as to easiest kit, best kit, what not to do..ect..
Thanks Roger
Thanks Roger
Tenons are not a problem for me, so I use the CUSA Euros. They have very nice platings.
If the tenon worries you, the new PSI Designer ballpoints do not require a tenon.
For the record, if you DO decide to make a Euro with a tenon, DO NOT secure the centerband with CA!!!!
If your tenon fit is precise, a press fit will hold the band nicely. If the fit is "just" undercut, red or blue Loctite thread compound will secure the band. If the tenon is severely undercut use a very small dab of 5 minute epoxy will work.
I make several hundred (maybe 1,000?) Euro pens per year. Not only is it virtually impossible to get CA in the right spot without ruining your finish, CA that comes in contact with the plated parts will actually destroy the plating. I noticed this several years ago on pens that had never been used, just sitting inventory.
WHAT'S WORSE, the instructions for ALMOST EVERY Euro sets SAYS USE CA!!!! I've had NO plating issues since changing from CA to Loctite.
