Bernie (Broken Bit) Thanks
ashaw
Phila, PA, USA.
Bernie
Thanks for your information requarding lose caps. I have made three barons and kept the couplers about 1/32"+ and epoxied the rings in place. So far no problems with the cap. No more o-rings.
I be playing with this on other screw capped pens and see if it also works.
Again thanks for the info.
Alan
ashaw
Phila, PA, USA.
Les
Instead to pushin to coupler and band all the way down. Leave about 1/31" that way the cap will thread all the way down. You will be to glue the band to the barrel. I have been turning my cigars and Barons without brass tube so I still have to glue the components into the blank. So gluing the ring to no issue. I you epoxy instead of CA do the the flumes muking up the plating.
Alan
