Berea Euro drill bit size?
patrick_1853
TN.
I posted a couple months ago asking what an alternative to the O size drill bit could be. I remember Old Griz answered me, but I can't remember the answer and can't find the post. Was it 5/16? Can't remember and don't want to go drilling into blanks without knowing.
Thanks,
Patrick
Old Griz
Passed Away Oct 4, 2013
Hagerstown, MD, USA.
I generally use either a 8mm or a 5/16"... the 5/16" is .0035 undersize but I have never had a problem and I use epoxy to glue all by tubes...
ctEaglesc
Passed Away Jul 4, 2008
Camden, S.C., USA.
You mean you guys actually Measure your bits?
Mine are so boogered up where they go in the Jacobs chuck,I cam't read them. I just "eyeball" em against the end of the tube.I try to go on the small side,I can always redrill them larger.
Rudy Vey
South Plainfield, NJ, USA.
If the kit calls for an "O" bit, I think the holes are a little bit too small, I have this problem with the Am Flattop pens. I have changed over to metric bits and use a 8.1 or 8.2 bit for these holes. The 5/16 is smaller than the "O", and instead of buying a metric bit, a "P" bit will do.
