tdibiasio
I have tuned many barons in the past, however last night I encountered a weird problem. During final assembly of the cap end, I slid the clip ring and finial into the tube and without using the press, I was able to seat the finial all the way in the tube. Usually I would have to use the press to get a good tight fit. I immediatly noticed that I was able to just pull the finial and clip out of the tube. [:0] I tried a finial from another kit and had the same results. I turn my pens between centers and use the bushings offered by Johnny CNC here on IAP. I can not remember if this is the first pen turned with set of bushings, and I am wondering if the bushings were such a tight fit that they expanded the tube ever so slightly.
Has this ever happened to anyone else, and if so is there a way to save the pen as I really like the way it turned out.
Thanks - Tom
Thanks - Tom
