PaulDoug
Can you glue pieces of bakelite together? If so what with? I was thinking about it tonight and it seems to be, back when I was a kid, if something made of bakelite, broke we couldn't repait it. Do the newer glues work?
I just broke a $30 bakelite rod drilling it for a Majestic. I pumped it full of CA, let it dry, then turned it. It left an exactly straight line along the glue joint. I put the clip over it and gave it to SWMBO. She loves it, BUT I KNOW IT"S BROKE!!!!!
We'll see what happens. I'll likely smack it with a hammer.
Andy, try the Colt 5 Star pen drill bits (make sure they are the pen bits). They go right through no problem. But I do use Pam cooking spray while drilling. Back out just 2 or 3 times to clean bit and respray with Pam. Have not cracked one yet or broke out the end. I drill at about 800-1000 rpm. And when you need a larger hole than Colt makes, just get as close to size as possible and finish with right size bit.
Hope this helps you out.
Keith "mrburls"
