Tiger
I've found TBC to be an accurate system for turning pens and avoiding the hassles that arise with using bushings that are inaccurate, out of round etc. The one thing I don't like much about it is the constant stop/starting the lathe to check measurements, this is amplified if use a CA finish as that will require even more stopping and starting of the lathe. In the past I've used outside calipers to turn to tenons when woodturning as i think it's difficult to use the digital calipers while the lathe is running. I guess we all learn to live with the constant measuring but I'm not sure that the constant stopping and starting of a lathe with electronic variable speed is good for the longevity of the lathe. Getting a seamless transition from the barrels to the pen parts is critical and is worth the extra time but sometimes I just find it a bit tedious to do the constant checking, be nice to fast track it a little.
