Atrax Rollerball barrel length
Krash
Albuquerque, NM
Hey, quick question for those who have worked with an Atrax rollerball.
Can the length of the upper or lower barrel be extended or do the components prohibit that freedom? I was wanting to lengthen the upper barrel a bit and wanted to make sure.
Thanks!
Dan Masshardt
Mechanicsburg, PA
The cap won't matter to be longer.
The pen tube will need a spacer or something added or a longer spring in the back or the refill tip won't stay out.
Ed McDonnell
Melbourne, FL
For what it's worth. When I need a spacer in an Atrax roller (usually because I switched to a postable finial, but sometimes because I added length) I cut up the little plastic cover that comes on the roller refill and stick that in the end. Works great.
Ed
