Woodnick43
Has anyone had a problem with the new PSI kits,American Patriot, Southwest and others in this series. I was having trouble with the American Patriot ballpoint pen, the refill is not retracting back all the way. After some fiddling I called PSI tech.dept. seems the assembly instructions in the kit are not correct, the instructions on the web site are correct. The tech. Told me my parts were not lined up and to take a dowel,wrap some sandpaper and sand the inside of the brass tube of the cap end. With the cap end off the pen,operating the transmission everything works fine, with the cap end on it is hard to extend the refill in and out. Did I not sand the tube enough or what???
Any help is greatly appreciated.
