yes ... me, too.
I saw Richard Kleinhenz's arrow pens -- and had to pursue making some as part of the Freedom pens I'm making.
So, I posted on a local barter newsgroup (Froogle showed $45/dozen for them!). A local guy sent me a dozen in a tube, on the promise I spot him back some pens, once done.
I've made 2 so far, and more today/now. I do this:
My simple slimline method:
- cut arrows to length of pen blanks/tubes
- measure inside of arrows: a wee bit larger than 7mm.
- Turn some pen blanks down REALLY thin (use cheap maple) and keep measuring with calipers to get it to the right thickness
- slide arrow shaft over the pen / glue in place
Important things I've learned:
- bevel transition between nib + arrow shaft, and at clip end,
BEFORE you slide it over the pen, using my grinder and twisting the arrow shaft (doh!)
- make a nice rounded cocobolo bead for the middle band,
provides nice transition between the 2 shafts
- Use chrome, black, or the gunmetal (titanium looking) kits for the camo arrows
Yes, its looks funky end-on: rings of brass tube, veneer of maple, aluminum shaft.
But then -- who sees that
-- joe
will post picts soon, digital camera loaned out right now
