davinci27
Here's the linkhttp://www.exoticblanks.com/index.p...ategory_id=23&option=com_virtuemart&Itemid=60
As I was browsing www.eroticblanks.com today, I came across this gorgous blank, and even though it scared me silly I ordered one. I've got a couple of ideas for this blank, but both require me to be able to see through the blank after the pen is assembled. So here are my 2 questions. First, has anybody turned one of these. If so any pointers for me.
Second how should I polish the inside of the blank after I've drilled it. I know I've seen some clear pens or pens with windows in them. How did you folks remove tooling marks from inside the blanks. I thought of maybe making some type of sanding dowel that i could insert after I drilled. or maybe using a small flame like you do on the edge of plexiglass after you cut it.
I probably should have ordered 2, cause I'm pretty sure I'm going to screw this one up. At least I know where to get more :biggrin:
