Antler pen question. - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 11-05-2018, 12:14 PM   #1 (permalink)
Photos: 0
Default Antler pen question.
I'm about to take my first run at turning deer antlers .
Anything special or magical I need to know ?
Thanks.
__________________
* The above post most likely has not been proof read nor grammatically correct. Spelling, ehh, 50/50 with spellcheck*
Have a Blessed Day, ivel
ivel is offline   Reply With Quote Top
Old 11-05-2018, 02:00 PM   #2 (permalink)
Photos: 0
Default
Just did my first one last weekend. SHARP cutters, light cuts. Hadn't been that long since I rotated the carbide, and I was thinking the antler was rock hard (it was, to be sure). Then, toward the end, I rotated the cutter--made life a LOT easier. What may be sharp for ebony may not be sharp enough for antler.
My novice observation--definitely not an expert!!
earl
greenacres2 is offline   Reply With Quote Top
Old 11-05-2018, 02:26 PM   #3 (permalink)
Photos: 12
Default
I find that cutting and drilling is the trickiest part due to odd shapes. Turning isn't so bad, but it does blunt the tools pretty quick. I use HSS spindle gouge, I use up the whole cutting edge and usually sharpen twice by the time I'm down to size. Depending on the size of the antler, it can be pretty porous. If its looking porous I usually fill with thin CA when I am a few thousands oversize then turn down to fit -- this just speeds up the finishing process for me.
The antler dust is a bit worse for the lungs compared to sawdust, so be sure to use a good DC or respirator (or both).
Last comment -- I would avoid using fresh antler. It holds moisture and can crack like wood during drying. I think typical drying time is 3 to 6 months. Many guys say they use fresh antler all the time without issues, others report cracking -- for me it just isn't worth the risk.
__________________
--Sam
Dehn0045 is online now   Reply With Quote Top
Advertisement
Old 11-05-2018, 05:57 PM   #4 (permalink)
terry q's Avatar
Photos: 0
Default
Make damn sure you have GOOD ventilation.
terry q is offline   Reply With Quote Top
Old 11-06-2018, 11:11 AM   #5 (permalink)
Photos: 0
Default
You could start by reading my article in the Library. P.
philipff is offline   Reply With Quote Top
Old 11-06-2018, 02:10 PM   #6 (permalink)
Woodchipper's Avatar
Photos: 1
Default
I''ll make it easy for all of us. Thanks, I ran across a piece of antler I need to use.
http://content.penturners.org/librar...er_on_pens.pdf
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 11-06-2018, 04:14 PM   #7 (permalink)
Photos: 1
Default
Selecting the right piece of antler is critical. Some people like tips that will make a nice hard and white surface, I feel that beam pieces make more interesting, and better selling, pens. My choice is always gnarly porous beam pieces. Fill them with CA 2-3 times as you turn them if necessary. I've made several hundreds of antler pens and those from beam stock, exposed bark and unusual coloration are always what sells best.
Drilling is a challenge but turning them round before drilling is not necessary. Mark the desired entrance and exit locations and drill a starter hole for each. I mount a drill bit in the headstock of my lathe, hold the antler piece with a large pliers, and use a live center in the tailstock quill to push the antler into the bit.
Some people claim they smell, if the antler is good and dry it won't smell as much. Definitely use a dust collector.
__________________
Often wrong, never in doubt.
Chasper is offline   Reply With Quote Top
Old 11-06-2018, 07:25 PM   #8 (permalink)
Photos: 12
Default
Gerry, that's a nice trick for drilling, thanks for sharing.
__________________
--Sam
Old 11-06-2018, 07:30 PM   #9 (permalink)
Photos: 0
Default
These antlers are from a fresh kill. So I need to wait several months before using them ?
__________________
Old 11-06-2018, 08:15 PM   #10 (permalink)
Photos: 1
Default
They will have to dry. When antlers are measured, there is a drying time before final measuring.
__________________
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
