problem is the pen is being turned the wrong way when turning the transmission! Ive seen customers do it when there in the workshop! They force it the wrong way, or just continue to turn the barrel evene when the nib is extended! This them loosens the transmission.
Then some have taken it apart and the pushed it together without fully screwing the transmission back in and therefore it gets trapped too far up the barrel? Or if they keep forcing the transmission around, it will also go up the barrel!
One even manage to get two springs in the nib, so the nib wouldnt turn, then forced the transmission! The it got jammed!
To get it out, knock the transmission through the top of the clip end, the top of the Sierra will detach from the clip, the the transmission can be pulled through! The squeeze back together!
PHIL
