Another lesson learned...
Warren White
Livermore, CA
...so many lessons; so little time.
I had a crack in my first acrylic pen during assembly today. I learned from it, so it isn't a total waste. However, it was a beautiful acrylic and it was a bummer.
The pen is a CSUSA Apprentice Fancy Slimline, so there isn't a lot of 'meat' covering the tube once it is turned. The blank cracked when I pressed the mechanism into the bottom of the pen. I did note that it started a little out of center, but I readjusted the pen and went ahead.
Now, the lesson I learned (other than the obvious one to be more careful) was that the brass tube had a burr on it following my squaring up the blank with Rick Herrell's offset jig. This is in NO WAY a reflection on Mr. Herrell's excellent jig. I love it! However, probably because of the grit of the sanding pad I am using (180 grit), there was a burr left on the brass tube. On my next pen, I used an Exacto blade to clean that up, and the pen assembly went fine.
I have sent a PM to Mr. Herrell asking what grit he recommends. I would be interested in anyone else chiming in as well.
So, if I have saved anyone the aggravation I went through, that is another positive outcome.
Thanks again for a great forum!
dtswebb
Modesto, California
A better way to remove any possible burr is to purchase a chamfering tool that is reloaders use. I purchased a chamfering tool several years ago and use it on all brass tubes. The chamfering tools are not expensive and I purchased mine at a local Bass Pro Shop.
flyitfast
San Antonio, TX 78247
I got a pipe deburring tool from HF that I use for all of my tube deburring needs.
Edit: a link to the tool I have.
I have used the same one for several years and it is one of my favorite tools. They are cheap enough that I have given many of them to fellow turners. Never had any obstructions since using it. Parts go into the tubes much easier and straighter.
Gordon
Dale Allen
Massillon, OH
180 grit is really aggressive in that application.
I use a worn out 220 or a 400 grit, by hand on a bar of aluminum with a centering peg.
Then I use a small pocket knife and chamfer the ID.
webberville, mi
CrimsonKeel beat me to a real good point. Best practice is to "seal" the ends prior to glue up to prevent glue buildup which can cause the cracking you describe. There are a number of materials used for this - I use modeling clay. Roll it out into a flat sheet (1/8") and then press the ends into it.
Couple other things - first, when you're pressing in, go with firm, steady pressure (no quick shocks). Second, know that different materials can take more "stretch" than others. Most woods have some "give", Tru-Stone doesn't. And different kits can require more care in assembly than others. A good practice is to do a light test fit before you get started.
The whole assembly thing can be a breeze or a nightmare. Some knowledge and up front work can help limit the nightmares.
Also, thanks for the tip on the deburring tool. I've been using a small pocket knife. Works ok but always looking for a better way.
Chromey
Pensacola
I also use a deburring tool like the ones pictured, mine is 20+ years old and I used it in HVAC for may years. The ones now have a plastic sleeve like that HF one, mine is metal and much heavier duty.
Tom T
Sanford Florida
HVAC me to. Still working. I have used a debarring tool on pipe and all. But silly me never thought to use it on a pen. Makes me wonder how sharp I am. Brass tub, is just a kind of pipe. The IAP rocks. You Guys and Gals are great.
