lago
I have drilled several with the 7mm bit and not problem. I messed up 2 blanks today when trying to drill with a 1/2" bit.
I did a search and it looks like some of you drill almost to the end but not all the way thru. That won't work for me since I am trying to get 2 pens out of one blank. I have some blanks that are about 5 1/4" long and trying to get a Gatsby and the PSI Lipstick pen. The blanks come out long enough for each tube if I cut with a Chinese flush-cut saw, which has a very small kerf. It just doesn't leave me with a blank long enough to stop before I get to the end.
I was using a brand new DeWalt 1/2 bradpoint bit at 200rpm and had a piece of wood under it.
Any suggestions other than using just over 1/2 of a blank for the Lipstick pen and toss the rest of the blank.
Lago
Lago
