jeffreybrown18
Is there any one who has Aluminum Pen Blanks for the PSI bolt action pens for sale. I have some guys in my unit that would love a pen with aluminum.
I suspected that. How many do you think you will need?The problem here on Okinawa is they don't do much manufacturing. so you can't
find much aluminum here on island and the stuff i find is very expensive. I found a piece that was 1"X 3' for 5000 yen that like $50
If the aluminum rod was the perfect diameter as your bushings (and it was drilled perfectly in center) and you just wanted it straight from bushing to bushing, you could just 'locktite' in the fittings and be pretty much done. Otherwise, you'll have to turn down the aluminum rod. I believe that most people use carbide-insert tools to make this happen. (Make sure that your tool rest is as close to your work as possible.)Maybe this is a case of "if you have to ask...", but here goes. What does making an aluminum bolt action blank entail? Just drilling a 3/8" hole in a piece of ~2" aluminum rod, or is there more to it?
Doesn't USPS allow the same flat rate shipping to you on base as in the US?
I buy my rod at hardware stores. a 6 foot section cost like 10 bucks. maybe try a local hardware? if not it will get pretty costly to ship. looks like 23 bucks shipping to a flat rate envelope
