Timbo
After I got the brass thing worked out (thanks to you guys), I thought Aluminum would be cinch...no such luck. I had a nice peice of black and white ebony, that segmented with blank/white pickguard, and aluminum. The aluminum separated the wood and the pickguard material. I used think CA to glue it all up, and didn't get back to it until the next day. I trimmed off the excess inlay on the bandsaw, and got to drilling...that's when things went downhill. The segments began to separate at the aluminum facings...both the wood and the pickguard sides. I know plenty of folks use aluminum without problems, so what did I do wrong. I prepard the aluminum by roughing it up with sandpaper before the glueup. As a matter of fact, you sould see the scratch pattern from the aluminum in the dried CA on the wood facing.
