USAFVET98
Ok guys, What drill bit size do I use for an aluminum blank if I dont want to use a brass barrel? I will be turning a 7mm pen...
I think you can get away with 1/4 inch...
-Barry
OK -- Why put a brass tube in an aluminum sleeve?? I do some micro-machining and there is not enough difference in the metals to add the step and the inherant problems of adding a brass tube inside an aluminum tube. Just use the same inside diameter -- but I am only working my way up from apprentice grade machinist....
Brad, odds are pretty good I sent you that blank.
Glad it worked out!:biggrin:
