Alternate kit...
GaryMadore
Ottawa, Ontario, Canada.
Hey gang,
Anybody out there know of any kits that use the same tubes as the .30 cal bolt action kits?
I have a couple of awesome cast blanks for the .30 cal kits but would rather build something more traditional.
I found a few that use the same diameter tubes, but they don't look to be the same length.
I figured that someone here may have a clue what I'm babbling about and have an answer ;)
Thanks,
Cheers!
Gary
magpens
Canada
A lot of the PSI kits use 3/8" diameter tubes, but
the .30 Cal Bolt Action tube is shorter than most other 3/8" tubes.
Please let us know if you find what you are looking for.
Cwalker935
Richmond, Va
The nouveau scepter uses a shorter 3/8" tube and you could the bolt action down to fit. The dragon and skull pens are also 3/8" and use shorter tubes but would require two tubes.
GaryMadore
Thanks everyone: I'll look at all of your recommendations.
I might bite the bullet (so to speak) Cody, and just get the bolt kits from somewhere.
Thanks again,
Gary
