Tiger
When you paint your tubes and inside your blanks is there a simple rule you can apply to drill bit size? For example if the tube normally calls for 25/64, do you drill 13/32 or 27/64. I know you can sand the inside hole but to keep everything concentric or reasonably so, drilling would be a better option. So in other words does anyone add a 1/64th or 1/32nd to compensate? Hate it when the paint in the hole gets scraped off because of not enough clearance.
