Alignment of material for Twist Pens
HuonFletch
Melbourne, Australia
Being relatively new to Pen Turning I was wondering which way people align the material on twist pens. Do you prefer to have the grain/pattern lined up when the pen nib is retracted or extended?
Up to now I have been aligning the pens so the grain/pattern in the materials for both halves is lined up when the pen is retracted. However I have noticed that a photo often looks better with the pen Nib extended but the grain then doesn't match.
What have you found to work best for presentation, photographs, sales etc?
Cheers!
sbell111
Franklin, TN
Whichever way you are presenting the pen, that's how the grain should align. We present our pens in pictures and on our sales table retracted, so that's how the grain is aligned.
Carl Fisher
Cape Coral, FL
Align when closed is the standard method.
Now if you want to get really tricky, some segmenting that aligns one way closed and another way open is always fun :biggrin:
randyrls
Harrisburg, PA 17112
Since most twist pens the cap can be removed and isn't threaded, you can do whichever is most pleasing to you and can be changed as easily as removing and attaching the cap.
Added later: Threaded capped pens have multi start threads, so the cap can be posted in one of three or four positions. Only one of the three thread starts will align the grain.
HuonFletch
I can't believe that I hadn't thought of that :rolleyes: - how obvious! - Photo's with pen aligned when nib is out, then realign cap for when nib is retracted.
