markgum
Hi all;
I tried to glue the tube in some spalted hackberry I have. I used CA glue let it set about 5 minutes then went to mill it; and the dang tube came out. I then tried thick CA glue, let it set another 10 minutes and the same thing. Now, I'm getting frustrated. I put gorilla glue on it; let it set a couple of minutes; slid the pen mill in to see what would happen; and must have gotten sloppy with the gorilla glue and pulled the tube out again and now it is GLUED on the mill.[B)]
I"m guessing the old spalted hackberry soaked up the glue. Maybe I should have put the glue on the wood, instead of on the tube. Maybe I shouldn't try hackberry for some of the first pens?
any advice would be appreciated...
p.s. don't tell the misses.. cause she will shoot me when I say I need a new pen mill....
thanks.
thanks.
