Advantages of Alumilite??? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 01-04-2019, 12:46 PM   #1 (permalink)
Bubba57's Avatar
Photos: 0
Default Advantages of Alumilite???
Turning my first, and probably last, Alumilite blank. It seems to be easy to work with but it just won't take a polish. At first I though it was me...or my blank, but a quick search of IAP reveals that not taking a polish is a common problem and the only solution is...CA. (That seems to be a solution to a LOT of problems in pen turning: Add some CA!)
But...that begs for the question to be asked: What are the advantages to Alumilite? It seemed to work nice but no better than AA, Rhino plastic, etc., and at twice the price. So...what am I missing?
Thanks in advance,
G.C. (Bubba) Parker
__________________
Oz never did give nothing to the pen man.
Bubba57 is offline   Reply With Quote Top
Old 01-04-2019, 01:02 PM   #2 (permalink)
RobS's Avatar
Photos: 105
Default
I find micro mesh polish through all the grits, then use McGuire's plastic polish to add more pop. If that does not do it, I polish it on the buffing wheel with white compound.
Aluminite tends to thread easily (I've made 5 kitless from it), and it can take an impact blow to it.
__________________
RobS
Oceanside, CA
RobS is offline   Reply With Quote Top
Old 01-04-2019, 01:58 PM   #3 (permalink)
MRDucks2's Avatar
Photos: 0
Default
My first Alumilite blank was a thin blue line and I was quite disappointed in my ability to get a high shine on it.
Since then I have cast my own Alumilite and been been able to polish up quite nicely. I have not cast any solid colors like the black of the thin blue line blank.
It is much less “chippy” on the lathe than rhinoplastic or Inlace Acrylester and quite durable.
From a casting perspective there are times I like the thicker viscosity of it as well as the short demold time and ability to work it pretty quickly.
I am still experimenting with what resin I like best from a casting perspective.
__________________
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Advertisement
Old 01-04-2019, 02:06 PM   #4 (permalink)
Chevota Guy's Avatar
Photos: 3
Default
Agree with both methods mentioned by RobS. I typically use Micro mesh (all grades), then follow up with Meguiars 17 Plastic Cleaner and lastly Meguiars 10 Plastic Polish.
Recently I tried wet sanding with 600 silicon carbide paper, followed immediately by buffing with Tripoli, then White Diamond. Lastly I buffed with Blue Jewelers polish and achieved a glass like shine.
I have read that Alumilite can't achieve quite as high a polish as Polyester, but to my eye I don't find that to be representative if finished as described above.
__________________
Dick Mahany
Chevota Guy is offline   Reply With Quote Top
Old 01-04-2019, 02:08 PM   #5 (permalink)
Photos: 37
Default
Meguiar's PlastX also works extremely well. I already had that in my car detailing arsenal.
brailsmt is offline   Reply With Quote Top
Old 01-04-2019, 02:28 PM   #6 (permalink)
Photos: 14
Default
For me, alumilite has some advantages compared to acrylic or PR :
  • The touch: close your eyes, press your thumb on it and move it forward. It slips like suede. Do the same with acrylic, it vibes in an unpleasant way. The feeling of temperature is different too, as if alumilite was warmer. The bad feeling of the plastic touch concerns acrylic, not alumilite.
  • The threads are strong and sharp. Acrylic can be a bit brittle but it works, PR is the weakest of all, making it a bad choice to get sustainable threading after long use.
To get a good shine with alumilite, when sanding with any grain you need to be sure you got rid of all scratches due to the coarser grain before, before using the next grain. Acrylic is much more forgiving, but a top-shiny look is possible with alumilite.
__________________
Pierre
Create more, kit less.
Pierre--- is offline   Reply With Quote Top
Old 01-04-2019, 02:59 PM   #7 (permalink)
Photos: 21
Default
My DiamondCast blanks are solely alumilite so I've got a bit of experience casting and finishing them...
Not that you asked this specifically, but from a casting perspective it cures quickly and you get a very durable blank that takes color well and feels good in the hand. As previously mentioned, it takes threads better than other resins which is important for custom makers that are not relying on kits.
Now... finishing seems to be the bane of many a pen maker and I see a lot of people spend WAY too much time fiddling with micromesh when there are faster ways to get the same results. It is absolutely critical to have a buffing system though.
I learned finishing with automotive systems... So I use what I know. If I do my job right turning a blank I can usually start with 800 grit, sometimes 600. If I've got something I need to sand out first, I'll drop down to 320 just to smooth things out and then work up. My usual schedule though is 800 grit, then 1200 grit then 2000 and polish. If I'm seeing some fine lines I'll use 3m polishing papers to get things smoothed out before I go to the buffing. You'll find this listed as Zona polishing paper usually at Amazon, etc. Typically I'll use two different buffing compounds and buffs. I use solely 3M compounds because I'm comfortable with them and having tried some of the plastic polishes, I think the 3M stuff does a better job.
The reason for not going crazy with micromesh or similar before buffing becomes obvious when you think about how buffing works. MOST heavy cut compounds are designed to remove 1200 grit or similar scratch patterns. Working through a bunch of MM grits down to 1 micron scratch patterns only to go use a heavier cutting compound is kind of a waste of time. I shouldn't even sand to 2000 grit before compounding but I just feel better getting a nice level surface.
Alumilite might not get quite as glossy as an acrylic but you CAN get it polished nice and shiny without sanding lines.
This one has a few fingerprints on it but gives you an idea: https://www.amazon.com/photos/shared...hoVZPtjdm28R57
McKenzie Penworks is offline   Reply With Quote Top
Old 01-04-2019, 03:35 PM   #8 (permalink)
Bubba57's Avatar
Photos: 0
Default
Thanks for the replies and info. Just what I needed to know...might be great stuff but not for my purposes...so why pay double/triple the price!
__________________
Old 01-04-2019, 03:41 PM   #9 (permalink)
Photos: 21
Default
Quote:
Not all alumilite blanks are created equal as well... If you'd like I'd be happy to send you one of mine to try out. Not saying I'll convert ya but I do like a challenge.
Old 01-04-2019, 05:14 PM   #10 (permalink)
mmayo's Avatar
Photos: 1
Default
Say yes!
I have several of the diamond blanks and they shine. It does take a bit longer but it is worth it to me.
__________________
Mark Mayo
Kites rise highest against the wind, not with it.
Winston Churchill
mmayo is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
