philthephlier
As a fairly new penturner (5 months) and still on the learning curve I have had my share of blown up acrylic blanks despite using sharp tools and varying speeds. I bought a carbide tool from an ebay store called unique tool. It is a 3/4" round carbide insert reground for a relief angle more appropriate for wood lathes. They machine a tapered 16" solid steel shaft and put a golf club handle on it and supply the tool with an allen wrench to loosen and reposition the insert for a fresh sharp edge. I have turned many blanks with it including 6 or 7 acrylic blanks @ 2700 rpm and with fairly light cuts I have not had a failure. The finish it leaves requires very little sanding and the insert hold it's edge very nicely. I have not used the tool enough to need sharpening but I am expecting that all it will need is a minute or two on a diamond stone to get it sharp again.
