mtgrizzly52
I put together a Wall Street II last evening with a navy blue acrylic blank I got at Woodcraft last week. I've used this same blank several times with no problems. I turned it with a skew and it turned perfectly, nice and smooth, no ripples and really needed very little sanding to smooth it out.
I hit is with 220/340/400 regular sandpaper, wet, and then through the MM 1500 to 12000 again wet sanding with each grit. I always clean my blanks between grits with denatured alcohol which has always worked very well for me.
Speed of sanding from 220 through 8000 was 1800 rpm, again, always use that speed with no problem, and then boosted the speed to about 2400 for the 12000 grit, again no problem.
Once I got through all the grits, I usually hit it with a bit of plastic polish and then a final coat of renaissance wax, speed at 2400 rpm.
Turned the lathe off, started to remove the mandrel and noticed what looked like a flaw in the acrylic blank that wasn't there a few seconds earlier. On the end of the acrylic nearest to the tailstock, it look like a wrinkle in the plastic. Running my fingers of the area confirmed what my eyes were seeing. It looks like the acrylic got really hot and melted, but how, when, why when a few seconds earlier that blank was a smooth as a baby's butt when I applied the wax?
This by the way definitely is not my first acrylic pen. I've done well over 50 of these, in several different types of pen kits with absolutely no problem before. Heck I've never even had a blowup with the acrylic, but I have with wood. This problem has really got me scratching my balding head.
Rick (mtgrizzly52)
Rick (mtgrizzly52)
