Jyd
Ok I had an Apollo Infinity Gold TN kit laying here and I purchased a Copper Lightning blank from BearTooth Woods to build this pen.
I have to say this is one of the best acrylic blanks I have used it drilled nice and turned very nice without chunks coming out. Turned the lower tube with no problem polished out and look fantastic. Turning the upper and getting close to bushing diameter and all at once the blank stops turning. I shut down and look things over and the blank has come loose from the tube and has two cracks on one end.
I did not think it was getting to hot, I have read here that it could cause my problem. It just looks like the epoxy never stuck to the blank, the tube is covered and it is bonded tight to it but the blank is smooth as a babies butt.
I have had problems with my last 3 pens when turning the blanks as I get close to final dimension. The first one was Spalted Maple and a piece popped off at the end. The second was a segmented blank from Woodcraft and I had the same problem a segmented piece came out, and the third is the acrylic above.
I am wondering if my epoxy has reached its shelf life or if I am just not doing my gluing process correctly. It is PSI 15 minute Mid Cure that was purchased with my starter kit in Oct. 2012.
Also has anyone tried polyurethane glue for building pens I thought maybe I could get better coverage as it foams up.
Any help is appreciated I am frustrated at this point and I don't need to toss anymore cash in the trash can.:frown:
