EdGallop41
I've been turning close to 200 pens so far, all but 2 are wood. I bought two Tru Stone acrylic blanks for two specialty gift pens. The first split apart as the drill broke through the bottom. Lucky for me, I could still use the blank after trimming 3/4" end off. When I drilled the second blank I used a drill stop and was careful to stop just before breaking through and only trimmed off 1/4". I also noticed the difference in drilling wood in that it will get hotter so it took much longer (backing out to cool). No problem turning them and they polished up nicely. I'm hooked... I ordered the necessary resin and dye but need better molds than PVC pipe. I do not know how to mix the colors to get the thin lines like in the Matrix design. What is a good mold source for detailed color mixing?
