Acrylester Crushed Gold Help
reddwil
Loganville, Georgia, USA.
Bought some Acrylester Crushed Gold blanks from Penn St, To make a shaving kit for my Son. The 1 1/2 blank turned fair with some chipping that I was able to work out. The 3/4 was a nightmare. I had good sharp tools and tried a gouge, skew and scraped, and could not get a good cut. It would only chip out and It finally shattered. I have never turned this stuff, has anyone had similar problems. What am I doing wrong? I got the brush made and now I'm without a blank or the time to get another one
ed4copies
Local Chapter Manager
Racine, WI, USA.
Redd,
That material IS chippy. BEAUTIFUL colors, but tricky to turn.
Hints: Take the corners off on a belt sander, before turning (make the blank round-ish).
When turning-turn down the ends of the blank first--so if it does "shatter" it is less likely to make a divot deeper than the finished pen.
Turn until you are about a sixteenth larger than you want and finish up with 220 grit (or so) sandpaper.
Spats139
Surrey, Canada
I've done about 80 inlace acrylester blanks recently, and only had problems with two; and those happened before the blanks even reached the lathe. I determined that I had drilled a little too aggressively, and the blanks had probably overheated and started to fracture from the inside out. Could this be a possibility in your case?
Other than that I haven't had any issues. Turn all blanks from square to final using a skew only.
Good luck on solving the problem because they are beautiful when you get them right.
thewishman
Reynoldsburg, Ohio, USA.
That stuff is chippy but has a very nice, almost grippy feel when polished.
You can repair some divots with a bit of the tiny chips and thin CA glue. You can also, on some blanks, fill with sanding dust from the blank like a slurry. Get some dust on a strip of sandpaper and add a drop of CA - sand back and forth over the chipped area and that will fill in the smaller divots.
We've all been there with a destroyed blank and no time to get a replacement. Got a silver blank? You could make a "Yukon Cornelius" Silver and Gold set.:wink:
