acetone or denatured alcohol - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 11-30-2018, 06:18 PM   #1 (permalink)
Photos: 0
Default acetone or denatured alcohol
Most directions say to use acetone to clean the brass before gluing in the tubes. Does denatured alcohol help in any way or is acetone a must? Thanks.
montmill is offline   Reply With Quote Top
Old 11-30-2018, 06:59 PM   #2 (permalink)
Herb G's Avatar
Photos: 18
Default
Use naphtha instead. Much cheaper & it evaporates a lot faster.
It's only for cleaning the brass so the glue sticks to it better anyway.
__________________
Be happy in your work...Col. Saito
My lathes:
Floor Lathe
Bench top lathe
Herb G is offline   Reply With Quote Top
Old 11-30-2018, 10:33 PM   #3 (permalink)
Photos: 12
Default
I don't use either and haven't had any related failures that I know about. I don't see a need for a solvent after roughing with sandpaper. Just my 2 cents and relatively small sample size ( couple hundred pens).
__________________
--Sam
Dehn0045 is offline   Reply With Quote Top
Advertisement
Old 11-30-2018, 10:49 PM   #4 (permalink)
BKelley's Avatar
Photos: 0
Default
Be careful with acetone or alcohol although they are good degreasers they can cause a tube to sweat. Napatha will leave an oily film. I have found gray scotch-Brite does a good job. It not removes oily finger prints, but roughens the brass slightly for a good grip.
Ben
__________________
A PROUD MEMBER OF THE GEORGIA CHAPTER IAP
BKelley is offline   Reply With Quote Top
Old 11-30-2018, 11:20 PM   #5 (permalink)
thewishman's Avatar
Photos: 0
Default
No sanding or chemical treatments for me.
__________________
Chris
Non Impedite Raditioni Cogitationis.
(Unencumbered by the thought process.)
Tom and Ray Magliozzi
thewishman is offline   Reply With Quote Top
Old 12-01-2018, 12:49 AM   #6 (permalink)
monophoto's Avatar
Photos: 0
Default
The point is to assure the strongest possible bond between the tube and the wood/plastic blank.
Wiping with acetone (or some other solvent) is intended to remove any grease left on the tube from its manufacturing process.
Many folks scuff the tube with an abrasive to provide a mildly rough surface for the glue to adhere better. The thinking is that the glue may not form a good chemical bond with the metal tube, but it will cure in the gap between the wood and the tube, and if the tube has been scratched, the glue will cure in those scratches to lock the tube into the blank mechanically.
__________________
Louie
http://monophoto.deviantart.com
Instagram: @louie_powell_photo
monophoto is offline   Reply With Quote Top
Old 12-01-2018, 03:05 AM   #7 (permalink)
randyrls's Avatar
Photos: 68
Default
I scuff the tube but don't use any degreaser. At a recent pen turning event, there were a LOT of failures because the wood split off the tube because the tubes were NOT scuffed.
__________________
Randy S.
Experience, ah, experience; Experience is what you get when you don't have experience!
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Old 12-01-2018, 06:51 AM   #8 (permalink)
Photos: 0
Default
Thanks for the information. It is very useful. I do scuff the tubes and have been careful about making sure the tube is covered in epoxy. I also twist the tube in one end, then remove it and insert it in the other end while twisting hopefully to smear the epoxy well so the entire inside is covered. Anything else I should be doing?
I've not done pens in a long time but last Christmas I gave our pastor a pen and this year her husband ordered seven to give to his management team. The gift that keeps on giving.
Old 12-01-2018, 07:21 AM   #9 (permalink)
Charlie_W's Avatar
Photos: 3
Default
I do scuff the tubes...usually between centers on the lathe and then file off any sharp edges on the ends of the tubes. Brass tubes make great scrapers .....as you will find out when you insert them into blanks which were painted inside. That is why I soften the sharp ends.
Back to the question...I will wipe the tubes prior to gluing with denatured alcohol. Even though the scuffing probably removed any manufacturing oils, I also want to clean the dust from sanding as well as my fingerprint oils.
Yes, 5 minute epoxy and I use a toothpick to spread some epoxy in each end of the blank as well as applying to the tube and most times I too insert from one end and then insert the tube from the other end for good glue coverage
__________________
Charlie W.
Charlie_W is online now   Reply With Quote Top
Old 12-01-2018, 05:51 PM   #10 (permalink)
Woodchipper's Avatar
Photos: 1
Default
I scuff with 150 sandpaper and wipe with denatured alcohol. Less water and dries fast. I have used acetone for other things but feel it's not needed on brass tubes.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
