dachemist
This is probably going to be kind of lengthy so I'd like to apologize in advance.
I have been unable to eliminate out of round issues on the pens I turn (I'd also like to apologize for bringing this topic up again). I've gone through the archives and I'm pretty sure I've read all the posts on this topic (as well as tried all the suggestions contained therein) but nothing has worked. I'm hoping someone will have a flash of inspiration after reading this (I have a thought or two that I'll mention a little later). First, here's what I've tried (not in any particular order):
1) Bought a bench top drill press (not really any better than using a hand held drill, at least in my hands) and a drill press vise (non-self centering). Returned the vise, bought a self-centering vise. Returned the drill press, bought a full size drill press (more on that later).
2) Discovered the centering vise jaw assembly had a tendency to bend toward the table when drilling, apparently causing the holes to be drill at an angle through the wood (though the offset should get turned out and not matter). Cut a piece of wood to support the handle of the vise and keep the jaw assembly from moving.
3) Realized mandrel was bent and replaced (3 times)
4) Noticed headstock and tailstock not lined up properly casuing the mandrel to visibly bend when advancing live center. Shimmed the tailstock with a piece of sandpaper, mandrel did not visibly bend.
5) Bought new (60° live center).
6) Replaced cheap PSI lathe w/VS Jet Mini.
7) Bought new tools (to replace cheap ones from PSI starter kit that came with 1st lathe). Bought low speed grinder from Woodcraft and Wolvering jig to sharpen new tools.
8) Gave up on MT mandrels, bought Beall collet chuck plus new mandrel rods (A & B from AS), plus pen kits for the B rod.
9) Bought new bushings, drill bits, digital caliper, new vise (the wood one from AS.
10) Finally called Jet about the tailstock issue, tried the 2 replacement tailstocks they sent me, then called Woodcraft (I'm hoping to pick up my replacement lathe tomorrow).
11) Tried sharpening my pen mill...oops...bought replacment cutter head for pen mill. Bought a disc sander from HF (the local store had a 1 day sale, $99 for the 12in sander, I figured it was worth a try), disc sander jig from PSI (unfortunately I don't have the equipment to try making the one in the article from Jay). Going to return both and go back to the pen mill.
If you've read this far, thank you for your patience.
I think one of the problems was buying a HF drill press (maybe I just got a bad one, that sort of luck runs in my family). I've tried using larger pieces of wood to allow enough to compensate for turning out the offset from the angled hole. My latest thinking is that the vibration caused by the (greater) uneven weight distribution is bending the mandrels (perhaps that should have been obvious to me sooner).
Also I'm wondering about the spindle alingment as well. I was sanding the outside of a small bowl (< 6" in dia) and noticed that the bowl and the handwheel were both wobbling quite a bit. I thought maybe the bowl was somehow out of balance (as a side note the few bowls I've turned have been "out of round" as well). I removed the bowl and faceplate and turned the lathe on again and the wobble was still there even with nothing on the spindle.
I'm going to give penturning one last try befor calling it quits. I want to try to eliminate as many issues as possible to make it a fair test. If I'm the problem I'm prepared to accept that. It would be a shame though, I think I'm finally starting to get the hang of finishing with Enduro...
Thank you againg for reading this, and for any advice.
Mike
Mike
