GregMuller
I would like some input on making a caseing pen useing the 8mm desinger euro style pen. I have made the slimline and cigar version and was looking at the 8mm useing 308 caseing. First problem I see is that the lower tube is much longer then the caseing. Not sure you can cut it and have the parker refill still fit. Also what to do with the coupling. Cover it or let it show. I know eagle uses this pen for many of his desigens so I am hopeing he will chime in here. So if anyone uses the 8mm desinger pen to make caseing pens any help would be welcome.
