8mm bullet pen
Gary Beasley
Marietta, Ga. USA
Anybody make your own 30.06 cartridge pens from an 8mm kit? I was comparing parts from a flat top kit with the setup I was working on after I stole the tube from it (this kit was missing its transmission too) thinking an 8mm tube would be easier, only problem is the nib size.
Sabaharr
Slidell, LA
If you can find a friend that is a reloader you might try using some actual 30 cal bullet tips and drill them for your nibs. They add some weight but the result is a more authentic looking bullet. I have some kits I bought "somewhere" years ago that I never put together that did this with .308 bullets. The blank looks awesome, I just have been too busy making sellable pens to try them out. Lord knows I have a few thousand 30 cal tips I could experiment with if I had the time since I reload them. Might be worth a "SHOT" if you want to try it out. Sorry, pun was irresistible.
lorbay
BC. Canada
I made 20 of these for a customer. They were nickle plated and I used a slimline trans with a real 8mm bullet. The 8mm makes a pretty big pen.
Lin.
KenV
Juneau, Alaska.
7mm tube fits into a 0.307 or 0.308 mouth of a 30 cal casing
8 mm pen tube is a bit too large for a 30 cal casing but fits into an 8mm or larger casing
Or you can make a bullet nib and adapt the tube to fit into the end of the bullet --
Slimline nib is almost perfect for a 30 cal case
